Cockshutt 20 questions....carb and spark plugs
Mark Jackson
09-18-2002 18:56:19
Hi folks...I'm in the middle of a Cockshutt 20 restoration and was hoping someone could help...I was looking for the correct spark plugs for the continental 140 engine...service manual just says Champion 8 common is all...also, this tractor has a Zenith carb on it...does anyone know where I could get a kit plus a couple other parts for this....the carb only says zenith...no other numbers or markings at all...thanks for the help!....I can be reached at [email protected]
mac
09-19-2002 20:02:36
 Re: Cockshutt 20 questions....carb and spark plugs in reply to Mark Jackson, 09-18-2002 18:56:19
Mark, one more idea...the Cockshutt 30 used a Zenith #161 carb. It's a shot in the dark but...
mac
09-19-2002 19:32:00
Mark, my book says carb is Marvel-Schebler model TSX-520. Try thecarburetorshop.com for a kit.
mark
09-19-2002 19:39:59
 Re: Re: Cockshutt 20 questions....carb and spark plugs in reply to mac, 09-19-2002 19:32:00
Thanks Mac...the manual I have says that a Zenith or a Marvel Shebler was available...but it doesn't have any seriel number breaks to say which was on what year...assuming I have the correct Zenith I'd like to find a kit for that and try it first...otherwise I will use your numbers and go looking for the Marvel Shebler...thanks much...Mark
mac
09-19-2002 19:57:48
 Re: Re: Re: Cockshutt 20 questions....carb and spark plugs in reply to mark, 09-19-2002 19:39:59
My 20 is s/n 124 (I think) but it came without a carb so I can't look at it. Good luck with your 20. They sure are cute.
Mac
Shutt30
09-20-2002 11:02:52
 Re: Re: Re: Re: Cockshutt 20 questions....carb and spark plugs in reply to mac, 09-19-2002 19:57:48
Mac, your serial # is 124? Mine is #137 with the 124 conntinental engine.
mac
09-20-2002 11:36:49
 Re: Re: Re: Re: Re: Cockshutt 20 questions....carb and spark plugs in reply to Shutt30, 09-20-2002 11:02:52
hmmm...I'll check it tonite. I may be confusing the s/n with the engine displacement. Yikes!
Shutt30
09-20-2002 12:57:22
 Re: Re: Re: Re: Re: Re: Cockshutt 20 questions....carb and spark plugs in reply to mac, 09-20-2002 11:36:49
I'm sure you know the serial # is on the frame and not the block.
