Compression Ratio w/ MW 3 7/8 High Dome on Oliver 88
Skippy
09-18-2002 04:21:28
What will the Compression Ratio be or Cranking Compression be with a set of M&W 3 7/8" high dome pistons in an Oliver 88 with a stock uncut head, and stock crank? What is the deck height @ TDC? Just trying to get an idea as to how much to shave the head. I do not want to go nuts but I feel around 9:1 will be a good number to shoot for.
A.P.
09-18-2002 09:31:22
 Re: Compression Ratio w/ MW 3 7/8 High Dome on Oliver 88 in reply to Skippy, 09-18-2002 04:21:28
The M&W set gives a 7.3 compression for an 88 head vs 6.8 stock. The Super 88 gets a 7.5 vs 7.0 and the 880 gets 7.8 vs 7.3. Apparently the chambersb in the Super 88 and 880 heads are slightly smaller than the 88 fleetline head. Hope this helps.
A.P.
Skippy
09-18-2002 09:55:19
 Re: Re: Compression Ratio w/ MW 3 7/8 High Dome on Oliver 88 in reply to A.P., 09-18-2002 09:31:22
What is the deck @ TDC? does the dome protrude above the block?
A.P.
09-18-2002 12:03:26
 Re: Re: Re: Compression Ratio w/ MW 3 7/8 High Dome on Oliver 88 in reply to Skippy, 09-18-2002 09:55:19
I am afraid that I do not have the deck height. The dome does protrude above the deck at TDC. I have heard that raising the piston about .15" will raise the compression to around 10.3-1. I haven't verified it myself so I am taking it with a grain of salt.
Good luck,
A.P.
