1850-2150 questions
Chip
09-16-2002 08:57:21
I'm going to a sale Sat with about 10 Olivers. There is a 2150 D and 2 1850 gas that I'm looking at. I have a 770 and a 880 so these are uncharted territory for me. Are these models any good? What price range should they be in? One of the 1850s is wf with a cab but it says "hasnt run for a while" could I throw a diesel in it? Thanks guys!
td
09-16-2002 09:31:25
 Re: 1850-2150 questions in reply to Chip, 09-16-2002 08:57:21
Where is the sale and does it list condition of the 2150?
Chip
09-19-2002 20:37:18
 Re: Re: 1850-2150 questions in reply to td, 09-16-2002 09:31:25
I went and looked at all of them tonight. The 2150 sounds good but has a faint knock starting that sounds like a rod bearing starting to loosen up. The pictures looked good, but up close most all of the tractors have been painted with a brush or can, and it looks like they bought whatever color of green was on sale. The sale is Sat. Go to Link and you can see the sale bill.
Larry from Maryland
09-16-2002 09:16:20
The 1850 gas and diesel have differant frames,so they are not as easy to switch as the 770's.
ol George
09-16-2002 19:39:28
 Re: Re: 1850-2150 questions in reply to Larry from Maryland, 09-16-2002 09:16:20
A motor out of a 17,18,or 1955 will fit in an 1850 gas tub.
Ian C. Campbell
09-16-2002 21:07:12
 Re: Re: Re: 1850-2150 questions in reply to ol George, 09-16-2002 19:39:28
Any waukesha/oliver from a 77 up to the 1855 will fit as said above, as the bolt spacing is the same. When I worked for an Oliver dealer we switched an 1800C gas which is the same front tub, to diesel using an 880 engine,and had basicly no problems. You may not want to switch it though as the gas motored 1850's are rarer than the diesels, and will actually start in the winter without a "wiff" of starting fluid.
