Wanting more POWER!!!
Oliver Puller
09-14-2002 17:32:59
Hello, I would like to get more power out of my 88. I don't want to rebuild it quite yet. What are some easy ways to get power. What is the compression supposed to be on an 88? Thank you.
Oliverman
09-16-2002 19:09:07
 Re: Wanting more POWER!!! in reply to Oliver Puller, 09-14-2002 17:32:59
the door is wide open you could plain the head a 1/8 of a inch that will give ya more compresstion. you could put a diffrent carb on like off of a 4030 john deere. try a hot coil like 45,000 or more volt. make sure you got good points. take a air grinder with a fine bit and polish the the ports in the head. take and get like a air filter at napa like to fit on your carberator and due away with the whole oil bath system. make sure your rockers are at the right gap. make sure govenor is at correct setting for maximum power. all that should make you have some more power. anytime oliverman
Oliver Puller
09-17-2002 13:50:29
 Re: Re: Wanting more POWER!!! in reply to Oliverman, 09-16-2002 19:09:07
Thanks a bunch!!!!
TimC
09-16-2002 08:41:02
1850 or 1650 diesel intake. bigger carb.
Darren
09-14-2002 20:02:22
Gas or diesel?
Oliver Puller
09-15-2002 16:49:43
 Re: Re: Wanting more POWER!!! in reply to Darren, 09-14-2002 20:02:22
Gas
Keddano
09-15-2002 18:46:58
 Re: Re: Re: Wanting more POWER!!! in reply to Oliver Puller, 09-15-2002 16:49:43
The cheapest is cutting the head about .125" and it will rise the compression greatly(you'll have to run high octane fuel).Also empty the oil bath out of the air cleaner and drill a dozen or so 1/2" holes down the side of the air cleaner(so it can breath easier). Next is bigger valves and pistons.It's all about money.
Darren
09-15-2002 19:01:52
 Re: Re: Re: Re: Wanting more POWER!!! in reply to Keddano, 09-15-2002 18:46:58
I think you could probably put larger jets in the carb, or maybe even put a carb from a 1650/1750 on it for more fuel...never done it myself but seems logical.
