Oliver Super 88 Diesel with WFE weighs?
Dean Van peurse
09-09-2002 14:55:46
How much would an Oliver Super 88 Diesel weigh with a WFE , 3 point hitch and one set of rear wheel weights?
Larry from Maryland
09-11-2002 16:29:27
 Re: Oliver Super 88 Diesel with WFE weighs? in reply to Dean Van peursem, 09-09-2002 14:55:46
The book I have shows the wide front as 188 pounds more than a narrow front.
Lynn Smith
09-11-2002 05:48:27
My Super 88 narrow front with fluid in the tires weighed in at approx. 6500#, because it just made the 6500# class pulling antique. Adding a wide front surely will add 200-300# more than a narrow front.
Bob
09-09-2002 18:45:25
I have a 880 gas n/f with 14.9/38s hydraulics, power traction 3 point hitch and two factory wheel weights --no fluid in tires , it weighs 5300 lbs bang on without me on it. You could add about 350-400lbs to that for the wide front. you probably weigh about 5750-5800
JD guy
09-09-2002 16:33:32
I looked this up in my 1958 tractor field book.
Nebraska test No. 527 Oliver S 88 diesel
Chassis type tricycle.
Total weight as tested 9465 lbs With operator. I know wheel weighs from the 88 i had are 150 lbs. Remember, the tractor in this test was probably weighted to the max.
deanVan peursem
09-09-2002 17:35:01
 Re: Re: Oliver Super 88 Diesel with WFE weighs? in reply to JD guy, 09-09-2002 16:33:32
Thanks for the info. Does the Nebraska test book give the starting weight or dry weight before they added ballast? The weights are about 150 lbs each, correct?
45RC60
09-17-2002 17:58:47
 Re: Re: Re: Oliver Super 88 Diesel with WFE weighs? in reply to deanVan peursem, 09-09-2002 17:35:01
Most of the weights we have are 150 but we have one smaller pair that must be 130.
Wrenchbender
09-09-2002 19:16:29
The Oliver rear wheel weights I have weigh 130 lbs each. WB.
JD guy
09-10-2002 03:39:41
 Re: Re: Re: Re: Oliver Super 88 Diesel with WFE weighs? in reply to Wrenchbender, 09-09-2002 19:16:29
I don't know about that! The weights i have from the 88 we had are 150. I just use them on the disk now. BTW the 88 we had was a really old one. I was a 88 but looked like 70
JD guy
09-09-2002 18:41:38
Most tractor weights are 150 lbs each.
As for the weight of the tractor in my book,it just said. Tatal weight as tested.
Hey i looked in the operators manual. I had a 88 but the book i have is for the S 77 and 88
The shipping weight of a RC S88 is 4700lbs
It don't say if that's for Gas or Diesel
They must have really put some weight on the one they tested.
