Any turbocharged 1850's out there?
Jim Mc
03-23-1999 07:32:27
I am considering installing a turbo onto one of our 1850's.We would be using the tractor mostly for plowing and chopping corn silage and haylage.I would appreciate hearing from anyone who has either installed one themselves or has used an 1850 that had a turbo. Did you gain much power? How about fuel economy? Does injecter pump need to be readjusted? Was it worth it? Thank you for any help.
mm
03-23-1999 17:02:17
 Re: Any turbocharged 1850's out there? in reply to Jim Mc, 03-23-1999 07:32:27
Hi, Whenever a turbo is installed on a diesel the rack must be enriched on the pump. If you don't the engine doesn't get more fuel for the additional air. Does you 1850 have a Perkins or Waukasha?
Jim Mc
03-23-1999 18:32:18
 Re: Re: Any turbocharged 1850's out there? in reply to mm, 03-23-1999 17:02:17
Thanks for the info., we have 2 1850's and they both have the perkins 352 deisal engine.
Danny
03-26-1999 13:46:25
 Re: Re: Re: Any turbocharged 1850's out there? in reply to Jim Mc, 03-23-1999 18:32:18
If you want to turbo your 1850, be careful about
your settings. The 354 Perkins turbo in a White
8800 combine makes 140 horsepower.That might be too much for your 1850's PTO.
Tom
03-26-1999 18:07:21
 Re: Re: Re: Re: Any turbocharged 1850's out there? in reply to Danny, 03-26-1999 13:46:25
Dont worry the 1850 can handle 140hp through the pto with no problem.The neighbor uses his on his chopper.The series three 354 perkins comes with two oil filters,turbo,and i think the motor turns a little slower.The big problem to watch for is heat,as the coling system is limited.The newer 354 have a revised head also which might help cooling.A cheaper way out is to use john deeres trick and just speed up the motor.Good luck.
