Oliver 70 Hubs
info seeker
09-04-2002 10:03:07
How many axle configurations are there on the Seventy model tractor. I need a nine bolt hub for a 70 axle that does not use the ubolt single keyed axle so I can use a pressed wheel as opposed to the cast rim that bolts to the wheel. The only other style of axle I have seen is the muti splined one. Thank You.
Ted
09-06-2002 17:57:38
 Re: Oliver 70 Hubs in reply to info seeker, 09-04-2002 10:03:07
I've had 6 70's over the years. All of them had splined axles,didn't matter if cast centers or hubs for pressed steel wheels. Let me know if you need a hub - I've got three.
jim
09-05-2002 15:43:47
look real close at john deere b or h hubs may be the same
john holcomb
09-04-2002 18:54:12
If you don't have a single key axle or a spline axle what does your axle look like? I have a number of 70.s but on the row crops the only thing I have seen is the splined axle.
info seeker
09-05-2002 10:05:29
 Re: Re: Oliver 70 Hubs in reply to john holcomb, 09-04-2002 18:54:12
Send Email I am blocked on the other server.
