Oliver 60 won't start.
Geoffrey
09-03-2002 19:23:38
I have had trouble starting my 60 since I did some engine repair. I checked everything I could think of - timing, compression, distributor, carb, etc. I did find that the upper shaft in the distributor had a lot of play and when investigated, I found one of the springs laying in the bottom. The little pin that holds it is broke off.
My question is would this completly prevent it from starting, and what could have caused it to break?
Thanks,
Geoffrey
info seeker
09-05-2002 10:33:10
 Re: Oliver 60 won't start. in reply to Geoffrey, 09-03-2002 19:23:38
Sounds like a no brainer to me. If all other things are correct then fix the distributor and try again. You will have the answer to you question and running engine or you will have eliminated another probable cause.
