770 lubrication
Jerry B
09-03-2002 09:06:32
I drained to oild from my 770 transmission and rear end. Or should I say I drained to water out of the trans/rear end? 4 gallons of rusty water and 1 quart of oily goo.
I ran 5 gallons of diesel through it and drained again. Let it set over night and then filled, ran it and drained again. Still geting rusty looking diesel from it. It has been draining for 2 days now.
I am tempted to just fill it with engine oil and run it with that for a while just to see what condition everyting is going to be in. It is my understanding that the transmission is supposed to run in 30 weight engine oil. True or false?
Should I opt for hydraulic fluid instead as it is slightly thicker and should provide a little more protection?
Any one got a better idea as to removing the rust from the internals of the gear boxes without removing the top cover?
Thanks.
Scott Green
09-03-2002 12:27:13
 Re: 770 lubrication in reply to Jerry B, 09-03-2002 09:06:32
I run 10W-30W oil in the engine and transmission of my Oliver "770". Yes , I would run it a while , then drain again.
