Oil lube gun
polk crawler
09-02-2002 07:33:42
Looking for a gun that dispeses oil rather than grease. Idlers and rollers on my OCs take oil according to specs. Thanks. PC
jld
09-02-2002 08:51:05
 Re: oil lube gun in reply to polk crawler, 09-02-2002 07:33:42
Used to use a regular Lincoln hand gun to pump 10 wt. hyd fluid. Will develop all the psi you could need. Remove the plunger and weld the hole shut in the end cap. Maybe not the finest but with a rubber hose and buttonhead coupler you should be in business.
OTC provided a gun with O-rings at one time but don't think it's still available.
polk crawler
09-02-2002 13:43:24
 Re: Re: oil lube gun in reply to jld, 09-02-2002 08:51:05
JLD:
Thanks; yours is the second suggestion modifying a grease gun. If it works, who could ask for more.
PC
