Super 55 (gas)
Craig Lainson
09-01-2002 21:04:51
I have a super 55 with possibly a 9v elec.system. There was a web sight that showed converting to 12v. Which generator to use and how to make a bracket. Can't find the sight. It now has an 8v. battery in it. Help. What is the least expensive and the smartest way to go from here. I think, but don't know for sure, that it originally had a 6v system. HELP,HELP,HELP
Gary Veldhuizen
09-14-2002 19:44:27
 Re: super 55 (gas) in reply to Craig Lainson, 09-01-2002 21:04:51
Get an intrnally regulated alternator off of a chevy car this Keep the starter the same and have a friend make you a bracket for mounting the altenator to the tractor.
jake
09-02-2002 09:07:09
The information you need is on this site under Research & Info. Go to articles and Upgrading Oliver 55 elecrical system. There ia a photo of the bracket is skown however ithas too much vibration which was cured by the addition of a 1/8 steel brace from the front of the alt and welded to the plate above the lower bolt hole, makes it rock solid. New scanner coming if a drawng wanted.
