Installing Sleeves
Ted
09-01-2002 18:03:48
When installing sleeves in a 66 should they go in by hand or do they need a little tap? What type of grease or ? do you use on the o-rings since the white lead paste my old manual talks about is likely not available.
TRAVIS
09-02-2002 06:42:45
 Re: Installing Sleeves in reply to Ted, 09-01-2002 18:03:48
The sleeves should go in fairly easy by hand if everything is good and clean. Lube the "o" rings either with siliclone paste or dish soap-do not use motor oil or grease. Make very sure everything is clean ecpecially the counter bore- install the sleaves first without the "o" ring in the block and check the sleeve protrusion. This is a often overlooked pocess, but it is critical to get a head gasket to seal. I'd have to look to be sure but I think the spec is .001" to .004" and they shouldn't be more than .002" different from each other. Good luck!
770
09-02-2002 08:47:03
 Re: Re: Installing Sleeves in reply to TRAVIS, 09-02-2002 06:42:45
Good advice Travis! The folks over at the old power seal co. always recommended mild dish soap. Grease is a no-no.
