Where do I add a valve on a Oliver 1855 ??????
COWBOY
08-31-2002 07:17:28
Have a Late Model Oliver 1855 with the White 2-105 Rear End. I am building a 3pt Log Splitter and want to put a valve on the splitter.
Where can I get live pressure and where should I put the return line? I know it is a closed hydraulic system and need a valve for that type.
I have a quick coupler on the lower left rear of the Hydraulic reservoir. Believe this is for a return line directly back????
Also,... How do I control the speed of the 3pt arms. They drop very quickly when I move the lever and need to slow them.
Wrenchbender
09-01-2002 08:12:52
 Re: Where do I add a valve on a Oliver 1855 ?????? in reply to COWBOY, 08-31-2002 07:17:28
I would just use one of your remotes and tie the lever with a tarp strap, then return the oil to the coupler you have to the lower left of the top link. The more fittings the more chances for leaks! If you don't need the remotes while using the splitter that is the easiest way to go. WB.
B A Star
08-31-2002 22:30:10
The first method for Power Beyond, was to install a "four way" fitting in place of the "three way" fitting on the left hand side of the hydraulic housing. Due to breakage problems caused by interference with the upper three point hitch arm, there was a fitting package that was installed in the line the goes around the rear of the hydraulic housing. The late fitting package is part number 30-3097714. It is covered in Service Bulletin #430 663. The three point hitch rate of drop was slowed down by installing a restrictor in the exhaust port of the Servo Valve that controls the three point hitch in the early tractors.
MikeO
08-31-2002 18:16:42
Oliver has (had) a different tee fitting that went on the upper left side of the hydraulics just under the seat. It had a fouth outlet to attach plumbing for a constant pressure coupling. We used this to power the remote valves on our sprayer and potato harvesting equipment. This is the easiest way to get constant pressure without tying off the valves. The lower coupler you spoke about should be the return line. It just drains back into the resevoir with no back pressure. Hope this helps.
Larry from Maryland
08-31-2002 13:44:10
The old oliver dealer used to have 3 wood stoves in it,and they hooked their splitter up to the remote outlets and tied the lever off with a rope.
COWBOY
08-31-2002 17:49:31
 Re: Re: Where do I add a valve on a Oliver 1855 ?????? in reply to Larry from Maryland, 08-31-2002 13:44:10
That was my plan if I can't get live hydraulics to a valve any other way.
But there must be a way,... But how is the question. I know I put power beyond in my Oliver 770 (But had a open center system)
There must be a way to find and adapt to a live line?
