Another 880 question
Red
08-30-2002 15:31:41
According to the serial number our 880 is a 1958. Then I read in a book that 1963 was the only year they had only 6 forward gears and 2 reverse. Well ours only has 6 forward and 2 reverse so I don't know if it is a 58 or a 63. I would appreciate any help.
D13
09-01-2002 03:57:14
 Re: Another 880 question in reply to Red, 08-30-2002 15:31:41
Believe your serial number.
The power booster is a 2-speed with an overrunning sprag. This effectively gave 12 forward and 4 reverse, with on-the-go shifting from low to direct.
The very late 880's MAY have had 3 point (I know the late 770's had it as an option).
Larry from Maryland
08-30-2002 15:44:02
You have a 58.The 6 by 2 transmission was used on all of them.Some had the 2 speed shift on the go tourque amplifier added between the engine and trans.
Red
08-30-2002 19:24:34
 Re: Re: Another 880 question in reply to Larry from Maryland, 08-30-2002 15:44:02
Larry, thanks for the information. So was the shift on the go added after production or did some of them come out with it?
COWBOY
08-31-2002 07:19:11
 Re: Re: Re: Another 880 question in reply to Red, 08-30-2002 19:24:34
Hey Red,...
The "Shift on the Go" was just a T/A that Oliver had and was a factory option.
