Need 1550 info
kevin
08-30-2002 13:19:20
i need to replace my rear tires and rims(rusted) on my oliver 1550. they have 18.4-30 on and i was told that is not the original size. anybody know the original size ?? thank you kevin
travis teets
09-03-2002 18:57:55
 Re: need 1550 info in reply to kevin, 08-30-2002 13:19:20
hello kevin, Maybe i can be of some help to you. i seen your ad and i hope you dont try to change anything on your 1550 tractor yet because of your responses. oliver built several different models of the 1550 and they had various wheel sizes. Oliver built the 1550 in an industrial model that had 13.00" x 24" rears . a wheatland model that had 16.9/14-30" rears or also 18.4/15-30" rears or 13.6/12-38" rears which were offered in regular or double beveled rims. A low profile utility which offered in 14.9x 28" powerjuster rims or 16.9x 28" powerjuster rims and 34" and 38" double bevel rims. and in the rowcrop, oliver offered the 12.4/11-38" rims in a powerjuster and 18.4-34" in powerjuster rims, or a rowcrop model in single bevel 34" and 38" rims or double bevel 34" and 38" rims. being your 1550 has the 30" rears i would probably look into it, but it sounds like a wheatland version and i would maybe wanna keep that original if that is what you think you might have, because they were a very low production tractor.... if you wanna talk, feel free to call me at 614-937-3955.....best of luck travis
DN
08-31-2002 07:04:25
my 1550 came with 15.5-38's
Larry from Maryland
08-30-2002 15:46:45
I have one with 16.9/28 tires.It is the short model not the row crop.
tl
08-30-2002 15:14:59
15-5-38
kevin
08-31-2002 16:13:27
 Re: Re: need 1550 info in reply to tl, 08-30-2002 15:14:59
thanks for the info guys, i want to return to the original size. kevin
