1855 PTO
TLS
08-29-2002 18:56:14
PTO trouble. Worked ok last fall. This spring pto
won't engage. Have 170 psi input to valve. pto turns by hand when engine isn't running or running and not engaged. Turn the valve on and there is some resistance to turning but can still be turned. Brake doesn't seem to engage and in gear the discs don't seem to try to turn the pto.
Wondering if I have to pull the unit for an internal problem or if the problem might be the valve or something external. Thanks for the help.
dave
08-29-2002 19:24:30
 Re: 1855 PTO in reply to TLS, 08-29-2002 18:56:14
You could possibly gotten 540/1000 shift rail in neutral. This is in the lower right corner of PTO housing.
