Where are Oliver 88 Serial Numbers?
mike
08-29-2002 17:19:29
I am interested in in knowing where the serial number plate is at on a Super 88 or 88. I thought it should be below the gauges and such but there isn't one there. The tin work is missing on the side and grill is gone. An implement dealer is selling it and I'm not sure if I believe it to be a Super. Tractor is in fair shape. Runs but needs tuneup and all tin work except hood. Asking $650 Offered $500 but couldn't touch it. Thanks for any info. Mike
evielboweviel
08-30-2002 15:58:32
 Re: Where are Oliver 88 Serial Numbers? in reply to mike, 08-29-2002 17:19:29
the super series has mounting pads on the frame next to the pipe holes. an 88 will only have pipe holes.
mike
08-31-2002 13:29:39
 Re: Re: Where are Oliver 88 Serial Numbers? in reply to evielboweviel, 08-30-2002 15:58:32
Thanks guys for the info, I'm going to look at it after the weekend and I'll let you know how I turn out.
Jerry B
08-30-2002 07:02:59
If you don't want it for $650 regardless of the exact model, I want it. Where is it located?
Jim T
08-29-2002 19:18:09
Mike, if the serial no. tag is not on the left lower portion of the dash, it's probably an 88. Look on the right side of the transmission case near the brake housing. Good luck. Jim T
