Oliver 35
Dan in Ore
08-22-2002 16:44:07
Who'd of thunk it, that I seen a tractor today that I never new existed. Does anyone have information on an Oliver 35? I can't find anyting out about the tractor, but today at the EDGE&TA national show I saw one of these. Pretty impresive tractor.
Ken Williams
08-23-2002 16:07:59
 Re: Oliver 35 in reply to Dan in Ore, 08-22-2002 16:44:07
Dear Dan, The Oliver 35 is the industrial version of the Oliver Standard 80. They are very closely related to the Oliver Industrial 80, with the difference being in what year they were made. Most serial number listings, show the Oliver 35 Industrial being made in only 1937 and 1938, but I own a Oliver 35 with a Industrial 80 serial number. My tractor has a serial number of 900334BC41, which would make it a 1943 under the Industrial 80's numbers. But it does show model 35 on the serial number tag. In any ways, they are a somewhat, hard to find tractor.
Dave
08-24-2002 16:52:54
 Re: Re: Oliver 35 in reply to Ken Williams, 08-23-2002 16:07:59
The first 440 Oliver 80 industrials were called 35 industrials,and had 35 on the serial number plate.After 440 they had 80 on the serial number pate.I also have a 35 industrial the last one built number 440.
Ken Williams
08-26-2002 12:22:48
 Re: Re: Re: Oliver 35 in reply to Dave, 08-24-2002 16:52:54
Dear Dave, what you say is true to an extent. But this is not the case, for all "35"s. As you can see by my serial number, it has a Ind.80 number, but only carries an Ind.35 tag with that serial number, and only Ind.35 markings. So there is an exception to every rule. Happy Tractoring, Ken
Dave
08-26-2002 18:16:48
 Re: Re: Re: Re: Oliver 35 in reply to Ken Williams, 08-26-2002 12:22:48
Ken i do not understand what you mean.It will have an 80 industrial serial number,and on the tag it will say 35 industrial.
Ken Williams
08-27-2002 14:57:06
 Re: Re: Re: Re: Re: Oliver 35 in reply to Dave, 08-26-2002 18:16:48
Dear Dave, Yes, you are correct. The serial number tag says Oliver 35, on top, and it has a serial number of 900334BC41. If it would help, I could try and send you a picture of the tag, and the tractor. Right know, the tractor is unrestored, but will make a good restoration project.
bobby britton
08-28-2002 08:03:17
 Re: Re: Re: Re: Re: Re: Oliver 35 in reply to Ken Williams, 08-27-2002 14:57:06
my dad also has a oliver 35. we have not been able to find out any info about it, any help will be greatly appreciated.the serial# is 900419kdc41 thanks bob
