Shift pattern model 70
pete
08-20-2002 09:04:13
can someone tell me which gears are where ?
FM...
08-20-2002 19:05:08
 Re: shift pattern model 70 in reply to pete, 08-20-2002 09:04:13
6 1
2
5 3
4 R
I hope that makes sense. To shift between say, 6 and 5, you have to come back an inch or two, over to the middle of the top neutral, and down to the bottom neutral, over to the left side of the bottome n. and then up to 5th. I hope that makes sense.
David C. Baker
08-20-2002 21:48:10
 Re: Re: shift pattern model 70 in reply to FM..., 08-20-2002 19:05:08
Now my 1948 70 Standard has the "H" pattern, but 5th and 6th are interchanged to what the reader gave you. 5th is right up near the push-button switch, and your knuckle can shut you down getting into 5th if you're not careful.
FM...Thanks
08-21-2002 19:40:09
 Re: Re: Re: shift pattern model 70 in reply to David C. Baker, 08-20-2002 21:48:10
I think I was wrong on that. I don't get into those high gears often enough to know which is which:-) As far as why, I have a stuck valve and no power..
