2-70 puller
Jack
08-14-2002 18:51:40
I have an old 2-70 sitting in the weeds. The other night at the tractor pull, I saw an Allis Challmer pull in a 6200lb class. It has a 301 motor in it. I am wondering what your thoughts would be on building this White with a turbocharged 310 out of a 1950-T. Do you all think that the rearend could handle more than just stock power? Also how much weight do you all think I could loose on it. I think it weighs around 8600lbs. Anyway thanks.
Nick
08-15-2002 03:16:09
 Re: 2-70 puller in reply to Jack, 08-14-2002 18:51:40
Jack, There is a guy near here in Southern Wisconsin that pulls 1655 with the original block and it sports well over 800 horsepower. He does well with it.
Nick
08-15-2002 03:16:07
Brad
08-14-2002 19:33:17
That tractor is the same as a 1655 and i would think it should handle a stock 310 no problem as long as you're not doing heavy work with it all the time.we had a 1655 as our main tractor for many years, only thing we ever put in was a clutch and batteries.good luck!
Jack
08-14-2002 18:52:31
I meant to mention it was a 190.
