Damage to 6V elect system
Polk Crawler
08-13-2002 09:58:49
Hitting all discussion boards to get an answer; ops manual says improperly connecting battery cables in a 6V positive ground system will result in damage. Will appreciate a definition and explanation of "damage", how serious it is to correct, etc.
System is on an OC3 dozer. Thanks PC
Dave Grubb
08-13-2002 10:40:25
 Re: damage to 6V elect system in reply to Polk Crawler, 08-13-2002 09:58:49
I'll try to give you a start. The worst thing is that you can damage the regulator, and less likely the generator.
When you connect the ground to negative you can, and probably will reverse polarize the regulator and possibly the generator.
There is a polarization procedure that must be followed when installing a new regulator or generator, and that same procedure should be used if you have reversed the cables. Rather than trying to go through the entire procedure here--which varies depending on the specifics of your system, go to:>Link
for>Link a good discussion on polarizing. Note: we don't have hyperlink here so you can cut and past that link.
Hope this helps.
tubba_JD420C_ny
08-13-2002 15:15:48
 Re: Re: damage to 6V elect system in reply to Dave Grubb, 08-13-2002 10:40:25
Thanks for the link. It looks like it covers polarization pretty well. It will come in handy as I am installing a new generator in my JD420C this weekend, and the polarity on that has been mixed up my the previous owner.
Polk Crawler
08-13-2002 16:22:03
 Re: Re: Re: damage to 6V elect system in reply to tubba_JD420C_ny, 08-13-2002 15:15:48
Ditto on article on polarization and the generator
Thanks for the reference PC
