Super 55 diesel questions
Kristian (Vt)
08-12-2002 17:26:42
I'm hoping some of you guys can help me with some general questions. I currently have a Ferguson TEA20 that I have outgrown. I have come across a Super 55 diesel for sale with a front end loader. My biggest question is how easy is it to get parts for this tractor? I plan on using the tractor for mowing. (I use a 5 foot finish mower on about 3 acres.) I also grade my driveway,push snow and rototille a large garden. I also do some logging occasionaly. The big things I need are the front end loader and the live PTO. The other questions are:
1. What is the horsepower for this model?
2. How hard is it to start one of these in the winter?
3. What is the approximate weight of this tractor?
Any other advice or information would be most appreciated.
Thanks!
Super 55
08-13-2002 08:41:30
 Re: Super 55 diesel questions in reply to Kristian (Vt), 08-12-2002 17:26:42
Mike is right about the power steering. If it doesn't have power steering don't use a front end loader. Shipping weight for that tractor is 3,000 pounds. By the way, I have a rather tired engine in my Super 55 and I use a heater in the lower rad hose to start in winter, but I am in the mild Pacific Northwest.
Mike (WA)
08-13-2002 08:35:56
You'll find the Oliver to be similar in handling, but a much more useful tractor than the Ferguson. All have independent PTO and live hydraulics (3 point works with clutch in our out). Hard starting in diesels is usually due to low compression, which can be detected from engine smoke. A little blue smoke on startup is OK, but should largely clear up when hot. White smoke is a bad thing. You'll probably have to use ether to start, but I've been starting mine on ether (in moderation) for 25 years, and if it's going to have a deleterious effect, it had better show up pretty soon or I'm gonna be too old to care. Tractor is about 35 HP, which should be plenty for what you're doing. Power steering is almost a necessity if you're using a loader. You also have to be gentle with the loader use, because the front end on the tractor is not heavy enough for rough use.
