310 water leak
Don
08-11-2002 14:40:20
I have a 1755 with the 310 in it. I just got it back from the shop because it was leaking coolant into the engine somewhere, but they couldnt find the problem anywhere. now, 2 hours since haveing it back, I noticed that the water pump is leaking out the weep hole. Could this be where the coolant is leaking into the oil? Only problem they found at the shop was that the head was warped .004"so the head shop shaved it flat again. What's your opinion?
TimC
08-12-2002 13:54:19
 Re: 310 water leak in reply to Don, 08-11-2002 14:40:20
The weep hole is there to let coolant out when the seal is leaking. Run it some more and the ceramic seal may smooth out and seal up if it is of that type.
The motor may have gotten hot and warped the head enough to allow some water in the oil but that is fixed now. Don't worry about it and keep a check on the fluid levels.
Don-WI
08-12-2002 20:33:58
 Re: Re: 310 water leak in reply to TimC, 08-12-2002 13:54:19
I am still running it, I need it to run the chopper while doing the straw, put about 5 hours on it since i noticed it, mainly hard running also.I plan to replace the pump, but I am keeping an eye on it, checking levels before getting it hot, and watching the temp and oil press gauges constantly. just have to watch and wait i guess.
Don-WI
Wrenchbender
08-11-2002 18:34:13
If you have coolant leaking into the oil it is probably the o-rings on the bottoms of the sleeves. WB.
