Oliver 660 wheels and 3 point
Mark Dorhout
08-06-2002 19:59:53
I recently purchased a 660. It has 13.6 X 38 wheels. Could these be original? What would be the reccommended tires? I also am planning to put a 3 point on this tractor. The three point is currently on a 770. Are their any issues with this fitting the 660?
B A Star
08-06-2002 21:06:31
 Re: Oliver 660 wheels and 3 point in reply to Mark Dorhout, 08-06-2002 19:59:53
The parts book shows that the largest tire used on the 660 was a 11 X 38. I don't think that the three point hitchs will interchange between a 77 / 770 and the 660. I think that the transmission housing is wider on the 770. A simple measurement will confirm it.
Scott Green
08-07-2002 01:57:29
 Re: Re: Oliver 660 wheels and 3 point in reply to B A Star, 08-06-2002 21:06:31
The "77" and the "770" 3 point should interchange ,unless it is a "power traction" 3 point hitch. The power traction 3 point also bolts under the bottom side of the tractor. The "77" and "super 77" do not have that mounting block under the tractor. Both the "770" and "880" tractors do have the mounting block. As far as the "660" tractor goes , I'm not shure with out looking it up. If I have time after work tonight , I might look that up.
