Ammeter on OC46
Polk Crawler
08-05-2002 19:51:07
On a recently acquired OC46 the ammeter shows discharge OK with ignition switch and light switch on; with engine running nothing registers on the charging side of the meter? Is the problem the voltage regulator or in the generator? No problem with run-down battery yet. Do I understand correctly the ammeter should register 4-5-6 amps charging with engine running even with battery up to par? PC
Phil (VA)
08-06-2002 11:24:57
 Re: ammeter on OC46 in reply to Polk Crawler, 08-05-2002 19:51:07
With light off and engine on should normally show very slight charge even with charged battery. Could be either VR or Gen. Put voltmeter on battery while running and it should show about 14 volts, or at least 1 to 2 more than when not running.
