77RC dsl won't start
shannon
07-30-2002 18:39:26
Just bought a 77 diesel that I had hauled about 30 miles from where it has been stored for the last 3 years with fuel in it. It ran when I originally looked at it and after I unloaded it at home, but when I pulled it off the trailer and parked it it refused to restart. The fuel was filthy and I figured I had churned it up hauling it home and now had clogged my injectors. Now I have drained and replaced the fuel but how do I get it to the injectors?
shannon
08-03-2002 08:31:06
 Re: 77RC dsl won't start in reply to shannon, 07-30-2002 18:39:26
I got the tractor to start after loosening the inject connections to get the fuel to them and then giving it a shot of starting fluid, ran it around the field once and shut it off. I haven't been able to start it since. Suggestions?
TimC
07-31-2002 12:42:07
Does it have a fuel filter???
If so then trash should not have gotten in the injectors.
There could have been some jell that passed. Loosen the injector fuel supply at each injector and crank it until you have cleared the lines after you replace the fuel filter. Retighten and start. Will probably run rough until it warms up and you run enough clean fuel through it.
