No start
keith
07-27-2002 17:33:25
HI GUYS have a 1951 oliver row crop 88 diesel, overhauled in 1998,ever since will not start when hot. i wait a half hour and it will start right up. i get no smoke of any color from exhaust when i try to restart,anyone have any ideas. thank you
B A Star
07-27-2002 20:07:48
 Re: no start in reply to keith, 07-27-2002 17:33:25
The problem is the fuel injection pump. It has enough wear, that when the fuel is hot, it is thin enough that it slips through the worn Hydarulic head in the pump. Cold fuel, is thick enough to not leak through the worn area. I'm sure that you can pull start it as the pump is now rotating fast enough to push the fuel to the nozzles before it can leak, You will need to replace the hydraulic head on the pump $$$$$$$$$$$$$
