1655-power steering leak
Mark in Wis.
07-16-2002 19:00:40
I have a small pinhole leak in the pipe going from the hydraulic pump to the power steering unit. Hole is located right on the bend after the pipe comes out from under the platform where it makes a 180 degree turn on its way to the hydro motor. What's the best way to repair/replace this pipe? Thanks for any help.
MikeO
07-17-2002 06:42:20
 Re: 1655-power steering leak in reply to Mark in Wis., 07-16-2002 19:00:40
Remove the fuel tank and the center platform around the shifter. Just did one this Sunday, took about 3-4 hours to do. Be sure to completely drain the fuel tank. Its a real challenge to remove.
