88 Shifting Problem
Kilian
07-08-2002 19:48:50
Have noticed the following problem when trying to shift my 88:
- If transmission is shifted into neutral at any point while engine is running and clutch is released, the gears grind when I go to shift back into a gear (clutch in, of course), both high and low range. A "ticking" sound can also be heard coming from the tranny in these situations while in neutral.
- If tractor is started while in gear (clutch in), it will shift well between all gears, both high and low range. Will only have problem if I put it in neutral.
Any thoughts? If I've been too confusing in the description I can clarify. Thanks for your help.
lc
07-15-2002 11:23:42
 Re: 88 Shifting Problem in reply to Kilian, 07-08-2002 19:48:50
I'd think maybe a dragging clutch or pilot bearing.
