HYDRAULIC REPAIR FOR SUPER 66
BRAD WATERS
07-07-2002 19:22:35
I HAVE A SUPER 66 DISEAL,AND IF I POUR HYDRAULIC OIL IN THE RESEIVER UNDER THE DASH,IT WILL LEAK OUT OF THE TRACTOR UNDERNEATH WHERE THE TRANSMISSION BOLTS TO THE REAREND,AND IF I POUR 1 AND A HALF GALLONS IN IT,IT WILL TAKE ABOUT 15 MINUTES AND ALL OF IT WILL BE DRAINED BACK OUT AND IT HAS A LOADER SO WHEN IT LEAKS AND THE PRESSURE DROPS THE LOADER WILL NOT RAISE,AND I HAVE TO POUR MORE OIL IN JUST TO BE ABLE TO MOVE THE TRACTOR,DOES ANYONE HAVE AN IDEA ABOUT WHAT THE PROBLEM MAY BE AND THE COST TO FIX IT?
Jeff
07-07-2002 22:18:19
 Re: HYDRAULIC REPAIR FOR SUPER 66 in reply to BRAD WATERS, 07-07-2002 19:22:35
About the only thing I can tell you is you'll have to pull off the hydraulic housing and see what's wrong. It could be something easy like a bad o-ring between the pump and housing or maybe bad seals on the pump. If you do decide to take off the housing, remember to pull the PTO shaft out first. Jeff.
