Cockshut 1550 hydraulic question
ROB MILLER
07-04-2002 11:15:43
I HAVE A COCKSHUT 1550 DIESEL WITH A FRONT END LOADER AND A NEW HYDRAULIC PUMP.
THE LOADER OPERATES SLOWLY UNLESS THE ENGINE IS SPEEDED UP. OTHER TRACTERS I HAVE HAD ARE MUCH FASTER AT THE LOWER RPM'S IS THERE ANY ADJUSTMENT, VALVE, OR CHANGING OF HYD HOSE SIZES THAT WILL MAKE A DIFFERENCE?
ANY HELP WOULD BE GREATLY APPRECIATED.
fireguy
shane
07-04-2002 12:24:55
 Re: cockshut 1550 hydraulic question in reply to ROB MILLER, 07-04-2002 11:15:43
Rob,Oliver hydraulics are the weakest link of their tractors.my 1550 is the same way,the nature of the brute,i guess.
j meyer
07-06-2002 08:04:34
 Re: Re: cockshut 1550 hydraulic question in reply to shane, 07-04-2002 12:24:55
we have never had hydraulic problems, i dont know where you are coming from. You have to remember these tractors are over 30 years old, and if they had abuse in the past, problems will occur!
Shane
07-06-2002 20:16:23
 Re: Re: Re: cockshut 1550 hydraulic question in reply to j meyer, 07-06-2002 08:04:34
so what if they have been abused in the past.the fact is oliver hydraulics are terrible.where are you coming from?the corner tavern?
j meyer
07-07-2002 09:22:03
 Re: Re: Re: Re: cockshut 1550 hydraulic question in reply to Shane, 07-06-2002 20:16:23
Hey Shane, sounds like you have some issues. If you wanna continue bickering over this, why dont you email me, because i know little kids are on here and they dont have to see you make an idiot of yourself. Now, I have never had a problem whatsoever on Oliver hydraulics if they are TAKEN care of. I have worked on these hydraulic systems before, so dont even start thinking I am some punk thats mouthing off, because I've been thru an Oliver. I'd like to see you mouth off to some of these other guys, like B A Star, WFE or better yet Larry Harsdorf, cause I know they will put you in your place just as fast. As I stated before, these tractors are over 30 years old, so if a tractor wasnt taken care of, problems will occur!!!
shane
07-07-2002 12:50:53
 Re: Re: Re: Re: Re: cockshut 1550 hydraulic question in reply to j meyer, 07-07-2002 09:22:03
what a moron....meyer knows everything,just ask him,he will tell you..you can have the last word.
j meyer
07-07-2002 13:55:15
 Re: Re: Re: Re: Re: Re: cockshut 1550 hydraulic question in reply to shane, 07-07-2002 12:50:53
Whatever Shane, you didnt even listen to my request. Now, if Rob is still following his original posting, I would first get the tractor flow rated. I had replaced a pump on a 1650 Oliver this year and it kept performing under spec. I'd first see what your system relief pressure is at. I dont have my books at home here, but I think its 2250, and you want to see how many gallons per minute its got 200 or so under. So, take the tractor up to rated (200 under, so say 2000) and see what the system tests at 100 degrees. If you get over 12gpm, you are doing alright. Remember, you have to allow for hoses and connections, that always knocks off a couple gpm's. Its a start, and if you need any more assistance, write me or re-post your message. Good luck to you:)
