My Oliver 1855 is loosing Oil Pressure when it gets up to temp. I totally rebuilt the engine last summer, except for the Oil Pump.Has 310 Waukasha, reground crank, all new bearings, piston/sleeves, etc. This has all the updates, and the integral Oil Cooler in the block. It only has abour 43 hours since rebuild. I have only used it during the cooler months so far. When it is started, it takes about 10 to 20 seconds for oil pressure to read on the gauge, (been doing this since I have got it) but climbs to 50 psi fast. This is at idle, and stays there till it warms up. Then when I use it a bit and the engine temp gets in the middle of the operating range, it only gets to 40 psi at full rpm,.. 18 psi at 1000 rpm,.. and 11 psi at idle. I checked oil level and it is fine. The engine is not overheating. Running 15w40 diesel oil and change it at 20 hours. Sounds like Oil Pump can't keep up the volume to the engine when hot. Thought of the relief valve, but would be low oil pressure all the time if stuck. So, it sounds like the Oil Pump.????? Has 4400 hours and believe it is original Oil Pump. I'm always open to suggestions from fellow mechanics. I am told that is what makes a good mechanic,.. "Someone who isn't afraid to ask for advice !!" Please put in your 2 cents worth.
