Semi-mounted sickle mower attachment
D13
07-01-2002 06:24:13
I have a semi-mounted sickle bar mower that the mounting on has been driving me crazy. The frame arms are pivot mounted to a large flat plate that has multiple mounting holes in it. The sickle lift is hydraulic. It is PTO driven, and has a PTO take-off and pull point for a crimper.
Ideally, the PTO shaft should be straight, and the crimper draw point should be aligned with the tractor centerline through the hitch. This would put all the load and the PTO shaft right down the center of the tractor.
I cannot find a position that satisfies both of these. If I satisfy either one the mower frame hits the tire. Also, the tip of the sickle is considerably forward of the base. In addition, bolting the plate to my drawbar seems to result in the frame hitting a tire.
If I move the mower back to get clear of the tire, the PTO shaft won�t reach.
If I move the sickle square to the tractor, the PTO and crimper pull point aren�t in line with the tractor centerline.
So far the best compromise seems to be to set the sickle square to the tractor, set the frame as far over as possible (to minimize the PTO shaft angle), and fab an adaptor.
Any ideas on what I�m doing wrong?
D Nelson
07-02-2002 11:48:23
 Re: Semi-mounted sickle mower attachment in reply to D13, 07-01-2002 06:24:13
I believe the mower you are describing is one that was designed for the drawbar of a 66/77/88 thru 660/770/880. The actual draw bar of the tractor is taken off. The flat plate with all the holes would have had two tabs bolted to it that would fit into the slot where the tractor drawbar would swing. You bolt the tabs on such that they line up with convenint holes and then drop a pin through the hole in the drawbar support and the hole in the tab. You may need to slide the rear wheel in to get a full cut and keep the PTO straight.
I have one of these mowers, except that mine does not have the attachment for pulling a crimper. It is a good mower and works great. I use it on a 770. It was originally purchased for a 77 and had a lever lift which was converted to hydraulic when my dad got the 770.
Good luck.
Don
