Front Grill for 77 and transmission
Ben
06-24-2002 23:50:58
I'am restoring a 1948 77 std. and I need a front grill ant leads? Also for some reason I can only get into 3 of the 6 forward gears and 1 of the 2 reverse gears. I need Help!
Warren
06-27-2002 09:23:54
 Re: Front Grill for 77 and transmission in reply to Ben, 06-24-2002 23:50:58
Ben,
From your post, it sounds like you are looking for the sheet metal grill for a 77. If so, I have an extra set that I would be willing to sell.
Let me know if you are still looking.
Tom
06-25-2002 17:41:07
Agree with Ben. Have had the same problem on our 77. It is not a difficult job.
WFE
06-25-2002 09:41:04
You can go to www.buyagparts.com and search for any parts including a grill. You can also place an online ad that vendors will answer and quote prices for you. Pretty handy. On the transmission, it sounds like the hi-lo shift rod isn't functioning, not allowing you to get into the other range. Better yank off the transmission cover/hydraulic housing/mechanical lift cover (whatever system you have) and take a look for a stuck shift rod, etc. Not too hard to do and the problem will probably be easy to spot. Good luck!
Ben
06-25-2002 20:33:13
 Re: Re: Front Grill for 77 and transmission in reply to WFE, 06-25-2002 09:41:04
there isent any springs under rubber boot area. would that have any thing to do with it
WFE
06-25-2002 22:30:42
 Re: Re: Re: Front Grill for 77 and transmission in reply to Ben, 06-25-2002 20:33:13
I believe you are referring to the centering springs and their absence shouldn't have an impact on whether or not you are able to shift gears, unless, I suppose, on of them were to break and bind the shift rod in place somehow. You won't be able to see them by removing the rubber boot, but you know they are there if the shifter centers itself in neutral. Still looks like you're going to have to pull that cover off and have a look-see. Nothing to it and no sweat. Good luck!
