Oliver 1365 engine
david
06-24-2002 21:04:43
I've got a 1365 with the Fiat 4 cylinder that has apparently lost oil pressure and seized. I've pulled the pan off and found the thrust washers ( all 4 halves ) and some pealed bearing material in the pan. Is this one worth fixing and where do I go about looking for parts. The tin is straight but the paint is pretty bad. How expensive is the Fiat to get parts for or is another engine the way to go? Thanks,David in Texas
klf
06-25-2002 21:37:29
 Re: oliver 1365 engine in reply to david , 06-24-2002 21:04:43
Hi Dave, my thrust bearins fell out too, but I put new ones in mine and was okay. I am suprised you didn't notice the thrust washers before, but if you don't use the PTO often, you wouldn't. If you want to rebuild that engine, I can get the parts for you. Just tell me what you need. Too bad you don't live closer, I would offer to buy it.
P.S. That engine was used in the 2-60 White, G450 MM, and I think the 5050 Allis. There are compatible Longs too, but I don't know which. The Fiats and Longs were mostly the same, except that one was made in Italy and the Longs in Chekislovakia (I know thats not spelled right).
