Need Governor for 550 gas
mpete
06-19-2002 18:27:28
I am looking for a governor shaft assembly for a 550. Missing some teeth on the gear, carrier has come off of shaft and carrier is damaged. Need at least a new shaft w/ carrier and gear assy.
Does anyone have a used one or know where I can find one?
Pete in Ks
06-20-2002 05:58:05
 Re: Need Governor for 550 gas in reply to mpete, 06-19-2002 18:27:28
You can get one through an AGCO dealer.
mpete
06-20-2002 09:10:08
 Re: Re: Need Governor for 550 gas in reply to Pete in Ks, 06-20-2002 05:58:05
Thanks Pete. I found one, but it is new and very expensive. Any ideas for a used one? Is there a design flaw with the originals that is fixed in the new ones?
Pete in Ks
06-21-2002 06:34:08
 Re: Re: Re: Need Governor for 550 gas in reply to mpete, 06-20-2002 09:10:08
Yes they are a bit high priced for no more than is there. The new one looked just like the old one when I replaced mine several years ago. Mine had around 5000 hrs. on it. These are moving parts and moving parts wear out. That is why I opted to go with new. If yours is a reaccuring problem you may have a different problem that needs addressed.
