Hubs spindles for 770
Brian (NE)
06-19-2002 09:42:21
I want to convert a 770 wide front to common implement rims & hubs. I want wider tires under the front end loader! Will the spindles match up to standard 6 bolt, 5 bolt or 4 bolt hubs? Or if someone has spindle dimensions (OD at each bearing and seal, plus length) I can look in catalogs at work to match to the aftermarket hubs.
Thanks,
Brian
