Horsepower of Oliver 1555
Alberta Tom
06-18-2002 22:30:04
Does anyone know the horsepower of the Oliver 1555? Also, any maintenance problems with this tractor? Availability of parts?
Thanks.
Sam M.
06-19-2002 11:25:07
 Re: Horsepower of Oliver 1555 in reply to Alberta Tom, 06-18-2002 22:30:04
I have a 1555 diesel . Horsepower is about 53 to 55 . Only maintenance problems I have had is with hydraulics which I think are weak for tractor this size . I have had tractor about 7 years and have put in two hydraulic pumps . My only other complaint is the diesel engine is cold cold natured and difficult to start when temperature is below 40 F . If you live outside South , count on needing ether to start or making sure air preheater works on the tractor when you buy the tractor . Oliver 1555 Tractor essentially has same frame size as 1655 which is 70 hp tractor . If you can get 1655 I would go with it instead of 1555 since they are basically same size . A friend has 1655 which can do a lot more work than my 1555. Also 1555 diesel has indirect fuel injectors which to me tend to smoke more than direct fuel injection which is on 1655 .
WFE
06-19-2002 07:10:02
If memory serves, the 1555 was Certified by Oliver to produce at least 53 hp in gasoline or diesel versions. No major problems with this model and a great little tractor. Parts are widely available through AGCO yet or through salvage yards, depending on what you might need.
