White 2-70 hydr.
Gene
06-18-2002 17:59:16
I have a white 2-70 that will not raise or lower a remote cylinder. I bought this tractor from a dealer 3 months ago and I do not have any history on it.
ms
06-20-2002 09:40:34
 Re: white 2-70 hydr. in reply to Gene, 06-18-2002 17:59:16
The noise in the arms is due to the linkage setting on the lever. Just raise the arms all the way up and turn the linkage until the pump stops squealing. The pump is trying to raise the arms when the cylinder is all the way up and the relief valve is squealing.
As for the remote, there is a restrictor valve on each side of the hydraulic unit that must be turned all the way out for full flow. The manual goes through the adjustments in detail although they are pretty easy to make.
marty g.
06-19-2002 04:58:15
Is the 3 Point hitch functionning properly?
Is the remote valve located underneat the seat on the left? Need more info on the set-up of that tractor.
Gene
06-20-2002 00:59:47
 Re: Re: white 2-70 hydr. in reply to marty g., 06-19-2002 04:58:15
The 3 point is working correctly. However, when the 3 point lever is up there is a noise coming from the hyd. system. If the lever is moved down 2 inches the noise stops.
marty g.
06-20-2002 05:11:04
 Re: Re: Re: white 2-70 hydr. in reply to Gene, 06-20-2002 00:59:47
Ours does the same thing. It's cause by oil cavitation in the system. Being an open type system, the oil is always being pumped and doing a round trip in the 3 point hitch system.
