My 66 oliver
missery
06-17-2002 17:36:17
what is the differences in the enginesfrom my 66 row crop to the 660 row crop?i noticed the carb is bigger on the 660.thanks,Dave
B A Star
06-17-2002 21:50:35
 Re: my 66 oliver in reply to missery, 06-17-2002 17:36:17
From 20 steps back the engines look similar, however there are a lot of differences. Start with the pistons, 3 7/16" dia. in the 66. 3 5/8" in the 660. compression ratio is about one point higher. Crankshaft connecting rod journals are larger in the 660. Camshaft lift is higher and valves are larger. Intake & exhaust manifolds flow more air/fuel. Governor is different allowing a higher rated RPM.
missery
06-19-2002 18:17:54
 Re: Re: my 66 oliver in reply to B A Star, 06-17-2002 21:50:35
will the 660 engine fit into my fleetline chassie on my 66? thanks for your help.
B A Star
06-19-2002 21:19:33
 Re: Re: Re: my 66 oliver in reply to missery, 06-19-2002 18:17:54
The 660 is a bolt in replacement.
