Where's the serial number on a 60?
Brian
06-14-2002 21:27:14
Just got home with my grandfather's only tractor. (Oliver 60) Dad and uncle Gene argued all afternoon about what year it is. Dad thinks its a '48, uncle Gene says its a '39 They do agree that it was sold new from the Oliver dealer in Independence IA. The serial number is the "tell all" on when it was built right? Brian
Scott Green
06-15-2002 05:03:28
 Re: Where's the serial number on a 60? in reply to Brian, 06-14-2002 21:27:14
Hi Brian , First of all , the serial number tag is on the side of the engine block , near the air breather. Now , Oliver may have started making the Oliver "60" tractor in 1939 according to serial numbers , I'm not shure. But , my book says they were made from 1940---1948. At a quick glance , you can tell the early Oliver "60" tractors from the late ones. The early ones have a strait shifting lever. It comes strait up out of the transmission. It was 1944 or 1945 when Oliver started useing the longer cross over shifting lever , like "66" , "77" , "88" etc.. Another quick glance change was the equalizer bar , which connected the left and right brake pedals. The earlyer ones did not have the equalizer bar.
Brian
06-16-2002 14:20:20
 Re: Re: Where's the serial number on a 60? in reply to Scott Green, 06-15-2002 05:03:28
Thanks for the info Scott. I found the tag under about a quarter inch of grease. 617504 is the number, it has a curve in the shift lever and an equalizer on the brakes. Uncle Gene says it has 2 transmissions? And it will run about 18 mph. This sounds a bit strange to me, since theres only one shift lever, and the Nebraska test shows it tops out at about 11 mph. Brian
Geoffrey
06-17-2002 18:14:08
 Re: Re: Re: Where's the serial number on a 60? in reply to Brian, 06-16-2002 14:20:20
I sure hope you didn't wire brush that tag and don't use sandpaper either. About the transmission, there is a high and low. It is best described as a double H. One is on top of the other. To move from one to the other , let the gearshift senter itself and then pull it straight down or up. In the forward range top left is slow reverse, lower left 1st, upper right 2nd, lower right 5th. In the rear range is top left fast reverse, lower left 3rd, upper right 4th, lower right 5th. The year of your 60 looks to be a 1947. Hope this helps a little.
Geoffrey
Brian
06-20-2002 21:45:00
 Re: Re: Re: Re: Where's the serial number on a 60? in reply to Geoffrey, 06-17-2002 18:14:08
Thanks for clearing up the shift pattern. Had no idea there were other gears in it. She runs real good now, the generator even worked, and the water pump doesn't leak. The only problem now is getting it to stop leaking coolant into the crankcase. Aparently during its 32 year nap with no coolant in the block, the o-rings have dried out and no longer seal the sleeves. I sure don't want to take it apart. I've seen sleeves crack and break before they budge. Several people have said Liquid Glass block sealer will seal it. Just have to get the slime out of the cooling system first. Thanks again. Brian
Brian
06-20-2002 21:48:52
 Re: Re: Re: Re: Re: Where's the serial number on a 60? in reply to Brian, 06-20-2002 21:45:00
Forgot to mention, are weights bolted to the inside of the rear wheel centers common on 60's? Brian
