Oliver alternator wiring
Jeff
06-13-2002 01:50:44
Hi, I'm trying to wire an alternator on a '52 Oliver 88 Row Crop. The alternator is a Delco Remy with a built in regulator. I put the wire from the amp meter onto the stud of the alt., green wire from switch to terminal #1, and terminal #2 back to alt. stud. A diode between #1 and switch. It won't give the coil spark. The two wires coming from the dash seem to have to be connected in order for the tractor to fire. But when I hook the alt. up like previously mentioned, it won't go. Any ideas? Appreciate the help, Jeff.
Larry from Maryland
06-13-2002 09:07:51
 Re: Oliver alternator wiring in reply to Jeff, 06-13-2002 01:50:44
You don't need an extra diode in the #1 wire.I guess you have changed polarity to negitive ground,so the connections on the ammeter need to be reversed along with the wires on the coil.
Jeff
06-14-2002 01:17:59
 Re: Re: Oliver alternator wiring in reply to Larry from Maryland, 06-13-2002 09:07:51
Larry, do you mean the wires for the ammeter and coil have to be reversed when it IS negative ground for the alt. to work? I did leave out the part that it is wired negative ground already. Thanks, Jeff.
Larry
06-14-2002 09:13:13
 Re: Re: Re: Oliver alternator wiring in reply to Jeff, 06-14-2002 01:17:59
No if it has been changed to neg before then leave it.
wiring diagram
06-14-2002 06:09:37
third party image
This one's for a Farmall but your Oliver should get wired the same.
If the image doesn't display go here: Link
