1850 dsl
Ron Parry
06-11-2002 20:10:10
I have and 1965 1850 and the pro and hydraulics stop working suddently, on power steering nothing. I would sure appreciate any help on what the problem is, hay season is here.
thanks Ron
Merlin in Saint Paul
06-11-2002 20:21:57
 Re: 1850 dsl in reply to Ron Parry, 06-11-2002 20:10:10
Hi, Ron! If you lost both the PTO and the hydraulics, then you probably stripped the forward splines off of the live power shaft, or the center may have stripped out of the pto drive hub in the flywheel. With the tractor SHUT OFF and the PTO in gear, see if you can turn the PTO shaft with a wrench or bar. If it rotates, and the engine does not, then this is the problem. The engine will have to be pulled to fix it, unless it is merely the PTO long shaft splines. You will probably need a new longshaft. Been there before with my 1950-T!
Merlin
Ron Parry
06-11-2002 20:52:50
 Re: Re: 1850 dsl in reply to Merlin in Saint Paul, 06-11-2002 20:21:57
Merlin thanks a lot I'll try it in the morning, Hay is geeting very ripe here in Pa. Ron
Shep
06-12-2002 05:41:57
 Re: Re: Re: 1850 dsl in reply to Ron Parry, 06-11-2002 20:52:50
You can pull the long PTO shaft out and see what the splines on the end look like. If the splines on the shaft are really worn out almost smooth then most of the damage was done to the shaft. You can get a new shaft and put it in and run the tractor through hay making season if you dont get too hard on it, but you will have to pull the engine and replace the hub in the flywheel that matches up with it. I have done this before to get me through crop season before, just dont let it go too long or you will ruin the new shaft, and they are about $250 for the shaft.
Ron Parry
06-25-2002 20:56:44
 Re: Re: Re: Re: 1850 dsl in reply to Shep, 06-12-2002 05:41:57
I pulled the shaft and the teeth are worn but they still there. We are planning to pull the engine, is the pto hub pressed into the pressure plate of bolted in also parts are a big question any suggestion sure would be appreciated.
