Oliver 1600 Hydrolic Oil Leak
Josh
06-09-2002 11:40:57
I've got a 1600 Oliver with a 1610 loader thats been leaking hydrolic oil pretty bad recently. It goes through about 3 gallons a day when running hard. I'ts leaking from the rear end and at first I thought there might've been a hole in the reservoir, but theres not. So my next guess would be that the rear end is going out. What do you guys think and how much would it cost to rebuild the rear end? Thanks.
Josh
Wrenchbender
06-10-2002 09:05:36
 Re: Oliver 1600 Hydrolic Oil Leak in reply to Josh, 06-09-2002 11:40:57
There is also a rod that activates the draft control. It has a seal on it. WB.
Larry from Maryland
06-09-2002 13:47:46
The 1600 has seperate hydrolic oil and rear end gear oil.If you have hyd oil leaking out the rear you have a leak into the rear from the hydrolic.The hydrolic pan maybe broken or the pump and it gasket are leaking.You must remove the whole hydrolic unit to fix.
