Generater bolt
phil
06-07-2002 13:03:48
I have a S55 1956 the threads that the long generater bolt threads into are shot. I tried to retap but the hole is now to large. Any ideas?
Ron Taylor
06-08-2002 00:21:45
 Re: generater bolt in reply to phil, 06-07-2002 13:03:48
You could popbably use a helicoil to get back to the proper thread size. The kit is usually availble at auto part stores. Good Luck
Hooter
06-07-2002 15:33:41
You might be able to helicoil it. That is the thread size you now tapped it for is smaller than the helicoil tap. Then you have Keen-serts that are uaed with an even larger tap. The Keen-sert will get you back to the stock size. Check with your local machine shop suppliers.
HOOT
