Need Cockshutt Piston Dimension
Charlie W.
06-05-2002 20:28:02
Does anyone know the length of the piston pin (center of pin) to piston top (deck)on a 30 Cockshutt tractor? This is the critical dimension on a piston swap over attempt I am making in one, and I don't have my pistons out yet. I would appriciate it if anyone can tell me.
Shut30
06-06-2002 05:08:04
 Re: Need Cockshutt Piston Dimension in reply to Charlie W., 06-05-2002 20:28:02
The compression distance is 2-25/64 or 2.390 according to my sealed power book. Good luck
Charlie W
06-06-2002 21:11:20
 Re: Re: Need Cockshutt Piston Dimension in reply to Shut30, 06-06-2002 05:08:04
Hmmm. That does not sound good for me. It may not work. Thanks.
Shutt 30
06-13-2002 19:29:10
 Re: Re: Re: Need Cockshutt Piston Dimension in reply to Charlie W, 06-06-2002 21:11:20
Find a 230 diesel Buda, The pistons with the knobs on top will fit with out grinding and you can run pump gas. Try Jim Cousins at the Buda engine Co. 1-318-222-3348 or budaengine.com Good luck
Al
06-06-2002 03:51:37
I will measure some i have in the shed after work.What are you thinking of putting in?(thought about the same thing,never was able to find a match)
Al
Charlie W
06-06-2002 21:23:19
 Re: Re: Need Cockshutt Piston Dimension in reply to Al, 06-06-2002 03:51:37
Shutt30's book shows it will not work. I wonder if that is a stock piston or a dome? Anyway, I was thinking that 4 pistons out of a Buda 6 cyl. combine engine would work if I had sleeves made custom for them. They are 3 9/16" dish pistons. The head is flat with the combustion chamber in the cylinder in the 6. This may be the difference. If that measurement is correct I would loose a lot of compression I think. What did your pistons measure?
Al
06-07-2002 16:43:57
 Re: Re: Re: Need Cockshutt Piston Dimension in reply to Charlie W, 06-06-2002 21:23:19
Checked the old piston tonight,the book is correct,stock piston,flat top,2.390.Hope I didn't shatter your dreams,there usually is no easy out,but it's worth checking out.
lol
Al
Al
06-07-2002 03:20:29
Sorry Charlie,Igot very busy last night,should find time tonight.I can tell you I tore down three 153's to build 1 ,two had 3&7/16 bore,one had 3&9/16 bore,all flat tops.
later
Al
