UPDATE: Oil leak from inspection plate on Super 55
Dan Cox
06-05-2002 07:54:24
Thanks to all that helped me with the Manifold issues I was having.. Please see my response to the original message a few pages in...
As for my oil leak.. I looked closer last night and found that it is coming from very high above the PTO clutch/drive shaft... Maybe even above the main drive. The previous owner replaced the steering box.. could there be oil coming from it? or does it just use grease?
Thanks,
Dan
jake
06-05-2002 09:50:25
 Re: UPDATE: Oil leak from inspection plate on Super 55 in reply to Dan Cox, 06-05-2002 07:54:24
There is a seal on the main cluth/PTO shaft however that is rather high. The steering gear could have either oil or light grease however it calls for 90 wt oil. If it is coming from the steering sear assy there is a hole in the bottom which is plugged by the use of a concave metal disc similar to freeze plugs, these can rust out or possibly just overlooked when the replacement was made. Keep us updated and good luck
