Super 77 diesel SMOKIN PROMBLEM !!!HELP!!!
Cory Hubbard
06-04-2002 21:29:57
I bought this tractor from a buddy of mine its a '53 super 77 with a six cyl. motor, well i drove it a little before i bought it and it did smoke a little bit. But when i bought it he said that he put new rings and bearings in the motor. But since i have been runing it it pours blue and white smoke! When you take the muffler off and run a stright pipe on it, it starts poping and cracking then when it warms up (about 30-45 min.) the blue and white start to go away then when you get on it blackish,whiteish smoke comes out, then when you reve it up and let off of it white smoke comes out. Then it starts running good just sittin there then when you start to climb a hill with it in 5th you can feel it jerk back and forth and it sounds like its running on about 3or4 cylinders then sounds like another one is wanting to fire but cant. I not much on diesels at this point but im learning a little. So what do yall think it is? Any help what be really appecated THANKS IN ADVANCE!!!!! !!
jim from ct.
06-05-2002 23:13:17
 Re: Super 77 diesel SMOKIN PROMBLEM !!!HELP!!! in reply to Cory Hubbard, 06-04-2002 21:29:57
your white smoke is probably due to low compression in one or more cylinders this could be caused by valves guides rings or cracked head. the black smoke is due to an over fuel condition possibly related to the above or bad nozzel tip. the fuel in the oil could be due to pump shaft seals lift pump or bad nozzle drip when engine is shut down leaking past rings.hope this helps.
Cory Hubbard
06-05-2002 19:52:22
Thanks for all the info! I havent got to use any of this info. yet but, you can pull the dipstick out and smell a real strong smell of diesel in the oil, and the oil runs off of the stick, not drip but runs off! The guy i bought it from also told me the reason he torn the tractor down was because the injection pump was pumping fuel into the crankcase. but he said that he bought another pump and put on it to fix this problem. But i dont know if that fixed it or not. THANKS for all the info!!!!! !!!!
m kuhns
06-05-2002 20:11:22
 Re: Re: Super 77 diesel SMOKIN PROMBLEM !!!HELP!!! in reply to Cory Hubbard, 06-05-2002 19:52:22
The fuel transfer pump on the right side of the engine could be leaking fuel oil in also. Timing that is off also can cause raw fuel to be drawn into the crankcase.
Dale Crisp
06-05-2002 18:19:46
The problem you are having is caused by raw fuel in the cylinders. This can be caused by two things. The first and most likely is one or more bad injectors. Most of the time this is caused by the tip of the injector being damaged while the head was off or by a small amount of water getting into the fuel system and by the fuel filter. The second thing would be low compression on one or more cylinders caused by valves not seating or rings not sealing.
m kuhns
06-05-2002 15:06:21
You could try cracking a line at a time at the injection pump to see if certain are actually not firing. Just start up the tractor and rev it up to where the miss is, and crack one line at a time to see if the rpms drop, or remains constant. You could have bad injector nozzles also. Another thing could be the timing of the injection pump. If it is off, symtoms are somewhat similar. A good quick check is to feel the exhaust manifold when starting the tractor when it is cold. If each port on the manifold is hot, each cylinder is firing. The ones that remain cold are not. These are some quick and simple checks for troubleshooting thatyou can use on diesels.
Larry from Maryland
06-05-2002 09:04:03
I would think you have sticking valves.Can be caused by no oil getting to them or parts of the head being too hot from a crack.I would remove the valve cover and run it while you watch the valves.
Cory Hubard
06-05-2002 10:13:02
 Re: Re: Super 77 diesel SMOKIN PROMBLEM !!!HELP!!! in reply to Larry from Maryland, 06-05-2002 09:04:03
When I first got the tractor i was going to tear it down and i took the valve cover off and the valves were getting oil. But i will pull the valve cover and whatch everything. THANKS!
