Busted PTO Oliver S55
Mark
06-03-2002 19:37:42
I just got done rototilling tonight. However, I pulled the PTO lever forward and it went way forward. I tried to re-engage the PTO but it no longer goes. Anyone have any thoughts.
Thanks
Mark
Pete
06-04-2002 19:33:30
 Re: Busted PTO Oliver S55 in reply to Mark, 06-03-2002 19:37:42
Mark
That adjustment should be 32# - measured 2' above the pivot point of the lever!
Pete
jake
06-03-2002 22:25:35
Take the inspection cover off the bottom and watch the function, you might have had the adjustment loose causing wear or burnt the discs. If the toggle assy moves try to tighten the adjustment nut clockwise till it takes 35# to engage the PTO. The grease fitting on the right side should be greased every 5 hrs of use.
Pete
06-03-2002 22:19:18
Mark
Sounds as if your brass shift collar assembly has just worn out and now broken letting the lever flop as it wouldn't be hooked to anything - you will have to do a split as there is no repairs that can be made as is! Good luck!
Pete
brian from ny
06-09-2002 20:45:50
 Re: Re: Busted PTO Oliver S55 in reply to Pete, 06-03-2002 22:19:18
I to have had this problem. I have two super 55's and they are great tractors. My newer 55 the one I have that has auxilary hydraulics and a new motor had this happen to me three years ago. The problem was the assembly that tightens and engages the pto blew apart. I got it fixed and it blew apart again ayear later.You will definately have to split the tractor to find the exact problem, be careful making sure that nothing is wore out somewhere else causing extra stress at the pto, as that was my problem which I found out the hard way. good luck BJW
