Super 55 diesel starter
Rickey Reed
06-03-2002 18:25:18
I am in need of a starter for my super 55 , fields and armature bad. where could I look , will anything else interchange. I'm being told
parts obsolete for 20 years.
Thanks for any help Rickey
jake
06-03-2002 22:35:16
 Re: super 55 diesel starter in reply to Rickey Reed, 06-03-2002 18:25:18
Delco starters 1108610,1108632,1108648 and 1107682 are 12 V which fit the 55. Instead of asking for a 55 starter ask for the above numbers. I found one at Carquest that way if I had asked for an Oliver starter all I would have gotten was a dumb look.
jake
06-06-2002 08:45:34
 Re: Re: super 55 diesel starter in reply to jake, 06-03-2002 22:35:16
If you are stiil at 6V you are stuck with 1107147 which is supported at the front and rear by bushings, with the distance between supports so far apart even one bad brush will cause the shaft to bend and drag the field poles and cause no start or burn out. The 12 V starters have a center bushing which prevents flexing. Just a little more info as I've been there. Also the 12V bendix have overriding clutches.
Pete
06-03-2002 22:27:55
Ricky
The last time that I had starter problems I had to have the armature rewound as the armature could not be found with the long shaft that the diesel starter takes - any good starter shop should be able to get this done for you - as I remember the fields were not a problem.
Good luck
Pete
